Engine Fan Not Running – Diagnostic Suggestions
Old 02-02-2012, 06:36 PM
rograham1's Avatar
Default Engine Fan Not Running – Diagnostic Suggestions
  • Make sure you have your radio code (from the dealer) and a record of your preset radio stations. Reset all of the residuals by removing the battery negative terminal, pumping the brakes to discharge the electrical system and reconnecting the battery negative terminal. You will need to reenter your radio code and preset stations when you are done with these diagnostics.
  • The engine fan has two fan speeds. The speeds are energized by signals from the ECM to the fan relay. The fan relay is designed to make sure that only ONE of the fan speeds can be energized.
  • It is important to note that if your cooling system were filled with pure water and was unpressurized, the water would boil over before the ECM would think it was hot enough to turn on the fan. IT IS VITAL THAT YOUR COOLANT SYSTEM BE A 50/50 MIX AND THAT IT RETAINS PRESSURE IN ORDER FOR THE COOLANT TO REACH A TEMPERATURE THAT WILL CAUSE THE ECM TO TURN ON THE FAN(S).
  • Due to the four layer sandwich design of the condenser/intercooler/radiator/fan assembly, the ECM is supposed to turn on the fan when the A/C compressor is running. So you might want to verify that condition by turning on the A/C or Defroster.
  • Bisect the diagnostics by checking whether the fans are functional since that is the easiest test.
  • With the car OFF, check if the fan blades are easily rotated.
  • With the car OFF, locate the plastic cover above the radiator.
  • Dislodge the plastic cover over the radiator by it pushing slightly toward the engine and lifting up (no screws or clips). This will give you easy access to the fan relay attached to it (slides off) under its left side.
  • There are multiple wires running to the fan relay in three connectors. You are interested in the middle connector. The middle connector has a yellow wire and a yellow/white wire.
  • Remove the middle connector from the relay. Inspect the connector for corrosion and clean if necessary.
  • Use a jumper wire to connect ONE of the exposed pins in the relay to ground (e.g. the engine right in front of you). You should hear the fan start spinning.
  • Use the same jumper wire to connect the other exposed pin in the relay to ground. You should hear the fan start spinning, but at a different speed than the first time.
  • If the fan doesn’t spin (and especially if it only spins on one jumped connection), then check the fuses to the left of the relay. Remove the little black covers and check them both. Alternately, you can use a VOM instead of your jumper wire on the exposed pins from before to measure whether voltage is present (which would mean that the corresponding fuse was good).
  • Reconnect the relay connector and reinstall the plastic cover.
  • If the fan does run at both speeds, then the ECM is not telling it to spin. The most fundamental but rare situation would be that both the wires (yellow, yellow/white) are broken/corroded. Leave that to the dealer since you need a special tool to remove the ECM. The ECM can also sense whether the yellow and yellow/white wires have an open circuit (sets codes).
  • The ECM turns on the fan when the Engine Coolant Temperature (ECT) sensor (a thermistor) delivers a very low resistance reading (e.g. 150 ohms). It will also turn on the fan when the ECT sensor indicates ultra-low or ultra-high temperatures (sets code) because it cannot trust the ECT sensor and this fail-safe mode helps ensure safe coolant temperatures.
  • The ECT sensor is located on the thermostat housing below the upper radiator hose where it meets the engine. It has relatively generous connecting wires to a simple connector that you can pull forward to gain access to that connector.
  • It is important to disconnect and inspect the contacts of this ECT sensor connector. It is possible that corrosion is slightly increasing the resistance which the ECM interprets to be a colder engine (so it never turns on the fan). When making any reconnection of this connector, make sure you can hear it snap into place.
  • If you want to confirm that the ECT sensor is functioning properly. Then get a candy thermometer and put it into the expansion tank with the cap off. Run the engine until it reaches 200 degrees F. Then turn off the engine, disconnect the ECT sensor connector and measure the resistance between the two contacts in the sensor’s pigtail. It should read about 200 ohms (which is NOT a low enough resistance to turn on the fans). Normal boiling point of water (212/100) will register about 180 ohms. The ECM is waiting for the ECT sensor to indicate resistance levels below about 160 ohms.
  • For further confirmation of ECM operation but possibly a bad ECT sensor, do the following.
    • Warm the engine to operating temperature and then turn it completely OFF. We are doing this to make sure the engine starts easily using a lean fuel mixture.
    • Reset the residuals (as above)
    • Locate or acquire two INSULATED alligator clip jumpers and a 150 Ohm resistor from an electronics hobby store.
    • Disconnect the ECT sensor connector.
    • On the connector end going to the ECM, put the two jumpers on the pins making sure they don’t contact each other.
    • Put the other ends of the jumpers on each side of the 150 Ohm resistor.
    • The resistor will now be pretending to be an ECT sensor thermistor that indicates a hot engine.
    • Make sure that the 150 Ohm resistor is not touching anything metal and will remain so when the engine is started.
    • Start the engine. The fan relay should energize and spin a fan motor. The engine temperature gauge should be reading hotter than the 3 o’clock position.
  • You can experiment with other resistances (never below 100 Ohms) to verify that the high fan speed kicks in, but this is usually unwarranted.
  • If the ECM operates the fans when you bypass the ECT sensor with a resistor as above, then replace the ECT sensor. Make sure to keep the ECT sensor connector protected from the coolant loss you may experience when you remove the upper radiator hose from the thermostat housing (in order to get easy access to the ECT sensor).
  • When you restart the car, make sure to top off the coolant (50/50 mix, not water). Remember that the system must be hot and pressurized in order for the ECM to turn on the fan.
Old 02-03-2012, 10:04 PM
What model car will this work on?
Old 02-13-2012, 07:09 AM
rograham1's Avatar
Default Possible Models for Fan Diagnostics
Here is a list of models that should apply to the post:
V40,S40 2000-2004,
S60 2001-2002,
C70 1999-2001,
V70 1998-2002,
XC70 1998-2002,
S70 1998-2000
Old 09-20-2012, 01:21 AM
norasaint's Avatar
I am trouble shooting a 960...fan motor works....fan relay works...unknown if the ECT sensor is functioning right if it is disconected the fan runs continuosly when hooked back up with ac on or defroster on fan motor doesn't engage. Could you send me a link to a repair manuel online that explains each componant involved in the system.
Old 09-20-2012, 11:53 PM
gdog's Avatar
Originally Posted by norasaint
I am trouble shooting a 960...fan motor works....fan relay works...unknown if the ECT sensor is functioning right if it is disconected the fan runs continuosly hen hooked back up ith ac on or defroster on fan motor doesnt engage. could you send me a link to a repair manuel online that explains each componant involved in the system.
Ck here:
http://www.matthewsvolvosite.com/volvo-wiring-diagrams
Old 09-24-2012, 08:47 AM
rograham1's Avatar
Default Fan should not go on
With the ECT sensor disconnected, the computer doesn't know the engine coolant temperature, so it must presume as a default that the coolant is too hot and turns on the engine fan. With a normally functioning ECT, the ENGINE fan should not go on until the coolant is almost boiling.
Are you trying to troubleshoot the VENTILATION fan?
Old 09-26-2012, 06:15 PM
DTX's Avatar
DTX
DTX is offline
Default 1993 850 Raditor Fan
After driving across town and I stop, the raditor fan continues to run for about 10-15 minutes. The coolant tank is full, had a thermostat put in about a month ago. Any suggestions.
Old 10-01-2012, 10:58 AM
rograham1's Avatar
1. Make sure that the fan does NOT turn on when you start the engine cold. If it DOES turn on, then you probably have a problem with your ECT (failed or bad connectors).
2. It is NORMAL for the fan to run-on after a drive. However, this may be an unusual duration for you now. Did you replace the thermostat with an IDENTICAL thermostat TEMPERATURE value? If you put in a hotter thermostat, you might see this condition.
Old 10-02-2012, 08:00 AM
DTX's Avatar
DTX
DTX is offline
Not sure if the thermastat was of equal value, but will replace it again and check the connectors. Thanks for the tips
Old 04-08-2013, 09:01 PM
Chuck35's Avatar
How do I remove the middle connector to the cooling fan relay to test the wires? I can't get it unplugged. Please help
Old 04-22-2013, 03:12 PM
98T5's Avatar
Bad fan relay. happend to me. made the car overheat. change it and everything is fine.
Old 09-24-2013, 04:50 AM
bobbysox's Avatar
Default fan problem
hi, this is a well thought out write up. but I have a 2001 Volvo v70, and I can't find any plastic piece on top of radiator, or any relay. is my model fan only controlled by the module on the fan. does the temp sensor send signal to fan module. if theres a relay were is it.
Old 09-24-2013, 07:27 AM
bobbysox's Avatar
I have a 2001 Volvo v70. don't see any relay for engine fan. does the module on the fan control off and on and the speeds? theres 12v the on connector all the time. i'm guessing, but theres a third small wire going to module maby this controls the module with a signal from who knows were, or whether it gets ground or 12v. if anyone out there knows anything about this, let me know. the problem i'm having is the ac stops working, because radiator fan stops and starts. getting new fan with module today. i'll let you know if this cures it. I olso got a temp sensor, but the temp gauge works fine, so I doubt if this is the problem. this Volvo is definetly hard to work on. thank's bob.
Old 09-24-2013, 05:15 PM
bobbysox's Avatar
ok guys and gals. problem ac goes off after driving it for a while. replaced cooling fan and temp sensor. did not fix problem. I had read in this forum about shimming compresser clutch, but had ignored it. well today while it was running with air on, but not working, I pushed on the clutch with a long screwdriver, bingo it pulled in. I wish I made this test before I got a new fan. i'll shim it tomorrow. hope this helps. bob.
Old 03-26-2014, 08:02 PM
habbyguy's Avatar
As Bobbysox mentioned, the 2001 V70 (mine's a T5) doesn't seem to be wired like the diagnostic description indicates. I was able to verify that I could command the ECM with my Vida / Dice machine to turn on the radiator fan at all three speeds (100%, 50%, and 25%). The control signal going into the one obvious small purple wire is a square wave, but measuring it with a DC voltmeter showed about 1.5VDC at 100%, 5.5VDC at 50% and around 10VDC at 25% (and nearly battery voltage when off). Crude, and the values you measure might vary depending on the voltmeter you use, but hopefully it will help someone out there diagnose an issue with their fan.
My real problem is that neither the A/C turning on, nor the engine reaching 95C (200F) is enough to turn the fan on. Very strange...
Old 03-27-2014, 03:35 PM
habbyguy's Avatar
Figured out two things... one, the A/C won't command the fan to come on until it's generating enough pressure (and my freon was a little low, so it never got there). Second, that the fan isn't commanded on until the coolant reaches 105 degrees, give or take. So now, my fan is on when it's supposed to be on, now that I've taken out a BAD replacement fan and put in the GOOD original fan...
Hopefully this info will help someone else down the line...
  #17
Old 01-24-2016, 11:38 AM
yappo's Avatar
Hi, my car overheats if I get caught in traffic but ok otherwise. Once when it overheated I topped up with just water so mix is probably not right. I have tried running car with A/C on but fan not working. I have tried to turn fan by hand with engine off and cannot turn it. any suggestions ?
  #18
Old 01-24-2016, 03:54 PM
tryingbe's Avatar
Seized motor, replace the fan motor or entire fan. Used or new.
I don't know your year, make, model.. so I would have to assume.
V70 volvo fan | eBay
  #19
Old 01-24-2016, 05:20 PM
yappo's Avatar
Thanks tryingbe I'm new to forum so haven't updated profile. It's a 2000 S70.
  #20
Old 05-16-2017, 05:26 PM
jenkinskg@yahoo.com's Avatar
I know it is an old thread but here is my 2 cents, Mine is newer s60 with fan controller, no relay. in vida could turn on fan directly all 3 speeds. But not turn on fan through ecu.
Was poking around and checking things, did have water, big non no but just did head and was dealing with a leak, it is resolved now.
Found temp sensor plug, on top of thermostat was not plugged in and is broken a little.
Pulled to verify fan would turn on with no sensor, then saw plastic cracked, put it back on and fan seems ok and runs after off as it should, next step is to use ecu to turn on fan. will let you know
Quick Reply: Engine Fan Not Running – Diagnostic Suggestions
