How do I remove the drip molding / install roof rails?
Need some help...
I've purchased a set of roof rails / euro rails to install on our 04 V70, and while I understand the basics about installing these, I have some questions... What is the best way to pop off the drip molding so that it can be cut? I don't want to break the clips underneath. Does anyone know what the part number or what these clips are called if I want to order some replacements?
Does anyone have instructions on how to mount the roof rails exactly? I've searched these forums and only came up with some vague information. The install .pdf seems to be missing from the Volvo download site and the local dealers here are such a pain to deal with....
any help would be appreciated, thanks
RE: How do I remove the drip molding / install roof rails?
I have a complete instruction set. Will able able to scan then and e-mail them to you Tuesday.
I purchased a new set to add to my 04 V70 this past July. They came with new plastic clips for every location. I believe the instruction sheet had the part number for the clips.
Removing and re-install is fairly straight forward. I am sure most people could do the second set in under an hour. I tend to be slow on a first time procedure.
To remove the existing: Start at the base of the windshield, grab the plastice moulding with fingers, and twist it out of the clips.
The instructions will accurately describe how and where to cut the moulding to fit back into place with the new rails.
Dennis
Dennis
I got my rails from Erivolvo as well. Iam pretty sure they are off a wrecked car. Great rails, rock solid.
I paid the local volvo dealer less than $75.00 to cut the trim and install the rails. In hindsight I could have done the work on my own but if I screwed up just one of the trim pieces it would have ended up costing me significantly more.
I also purchased a brake booster from Erivolvo for minimal dollars, no issues so far.
Brent
Brent
rails V70 II
Dennis
Dennis
I would be very pleased if you would send the instructions to me too.
It's possible?
MY email is: gianni.nardoia(at)email.it
thank you. bye. Gianni.
roof rails instructions
I have them in a pdf only for the 2001-2007 v70. They are not difficult.
Some unsolicited pointers:
- Do the passenger side first. That way if you screw up you won't likely notice it on that side and you will learn before you do the drivers side. The aluminum moldings can bend easily, although that won't be a problem if you take your time. The first side will take an hour and half, the other side fifteen minutes.
- Remover the molding starting from the rear of the car and you won't damage any clips. The clips next to the windshield are the most difficult to work with. If you are patient you can do the whole job without ever removing the last section and disturbing the clips on the windshield. I laid blankets on the car and cut the moldings with a hack saw blade at each mounting point. I never removed the front section or disturbed the clips.
Here is link for install directions
CT_V70 kindly posted the directions on a share site he uses.
Please download the file from here:
http://www.box.net/shared/c20duosyf1
#17
Roof Rail Instructions for 2000-2007 v70
I have them scanned. Email me at hovonogila@gmail.com and I will send them to you. Easiest way to do this, is do the passenger side first. That way you won't see the boo-boo's that no else will ever notice. I remove the molding from the back and leave the clips at the windscreen intact. They are the trickiest to install. I laid a blanket on top of the car, under the molding, and put tape on the molding paint surface in case the hacksaw jumped. These parts are extruded aluminum and if you twice or bend them they will damage. Be gentle and patient. The first side will take you an hour-and-a-half and the second side fifteen minutes.
#18
hovonogila
05-16-2019 02:28 AM
Lizella Fella
01-03-2013 08:22 AM
