Dash board goes blank, Bad ABS Module?
Old 09-21-2010, 06:47 PM
jeepcherokee87's Avatar
Default Dash board goes blank, Bad ABS Module?
I have a 2001 V70 T5 and trying to figure out why the odometer, speedometer, everything goes blank after driving it for a couple of minutes. I read a thread on another site saying it was a motorola chip on the DIM panel. I tried getting that soldered today and it didn't help. I am thinking it may be the ABS module after reading the posts around here but don't really want to throw anymore money away. Do my symptoms sound like maybe a bad ABS module?
Everything works fine for the first couple of minutes. Then the ABS and Brake lights will come on about 5 seconds before the whole dash dies. Speedometer RPM gauge, everything goes blank. Signals won't work, windows won't roll down. Thanks for any help you can give me.
Old 09-21-2010, 06:59 PM
Forgot to mention, the SRS Service light is on in the message center. Thanks
Old 09-22-2010, 01:47 PM
fredneck's Avatar
Check Vic Rocha's site at vicrocha@earthlink.
This guy will rebuild your old abs unit. Apparently half the car is wired thru the abs unit (saved $1 doing it this way, I guess). When the reputer cards inside the unit go bad, all hell breaks loose, dash, transmission, the works. He will rebuild your unit very cost effectively, guarantee it, all in a short time period. I have used this guy in the past and as far as I'm concerned, he's 100% reliable. Only hangup is he's in CAlifornia. But with priority mail, it's pretty quick.
VolvoFred
08-27-2010 09:09 AM
Cefore
05-03-2009 03:49 PM
fencerider
02-21-2009 09:14 AM
malibu2
11-26-2007 11:05 PM
Quick Reply: Dash board goes blank, Bad ABS Module?
