Help 2001 Volvo V70
Which engine do you have?
First is do you have any CEL codes stored? Next is how do you know the coils are good - Did you inspect the connectors as well? Have you failed a smog test already - if so what was off - HCs or NOxs? (too high HCs = running rich, too high NOxs = running lean). Have you tested out the MAF? Tested or cleaned the idle control valve? Inspected for vacuum lines and intake tubes or sprayed around for air leaks?
climbca
02-24-2013 02:03 AM
Subvol
12-11-2011 06:56 PM
schott1984
09-24-2010 09:15 PM
