ticking noise on 98 V 70
Old 10-10-2006, 06:34 AM
dj296's Avatar
Default ticking noise on 98 V 70
sometimes when I left the car running idle for 5-10 minutes, there is a clicking/ticking noise comes from the engine (sounds like valve noise), but after I use the car for sometimes, the clicking/ticking noise dissapeared.
any comment?
Old 10-10-2006, 09:45 PM
Default RE: ticking noise on 98 V 70
Most likely the oil pan O-rings.
Old 11-09-2006, 02:41 AM
eyukins's Avatar
tech,
When you get a chance can you please explain that one? I don't get it, oil pan o-rings? What are they and how would they make a noise?
Not that I'm doubting your advice, it's always right on.
Old 11-09-2006, 08:50 PM
The oil pan o-rings go between the oil pan and the engine. There is oil ports that go through the oil pan and the engine. When the o-rings go bad oikl pressure is lost and causes a tapping noise from the top of the engine.
check out this post for replacing them and where they are.
https://volvoforums.com/m_6169/tm.htm
handal_paul
11-04-2008 11:51 AM
Capo Cam
02-23-2008 10:19 PM
master_pre
01-20-2008 09:17 PM
detrock
12-23-2007 05:30 AM
erdal
05-30-2005 02:51 AM
Quick Reply: ticking noise on 98 V 70
