Vibration woes
Vibration woes
I have a 1999 T5 with 100K that has a low harmonic vibration at idle,when you shift the automatic from Park or Neutral into Drive or Reverse the vibration is felt. I have checked all mounts and that does not seem to be the issue,also have pulled the front damper
inspected it then re-installed it at 180 degrees from original with a small bit of improvement noticed.What have I overlooked or missed?
Thanks in advance
Glenn B
RE: Vibration woes
Thanks Tech for your info. I am a newbie to Volvo's and might ask some stupid questions from time to time. I have replaced the top bushing as it was definately in need of. When I had the car on the hoist the 2 motor mounts showed no sign of leaking and when I lifted the engine via a large bar didn't seem to have a lot of movement but there was certainly some. I am not sure as to what is exceptable.
Any help would be greatly appreciated or suggestions as to where or what to look at next.
thanks again
glenn
thanks again
glenn
