maple syrup smell from A/C
RE: maple syrup smell from A/C
pressurize the coolant system and see if it holds pressure if it does not it is leaking somewhere check your coolant level is it going down any? Check your water pump any cracked hoses, radiator,hoses going through firewall to the heater core. You did not have any other work done to the car recently that may have caused a leak have you?
ORIGINAL: b5254t
I will go out here and do a thorough check for leaks all over the engine bay just to be sure.
ORIGINAL: jks2
If you can't find the leak, I suggest a tall stack of buckwheat pancakes. Seriously, do you notice a dampness in the carpet? It could be a small leak that is being soaked up before you can see it.
