Metal to Metal sound in back of Engine
Old 07-09-2010, 02:00 PM
checksix's Avatar
Default Metal to Metal sound in back of Engine
I have friend who drives I'd guess an 850 wagon (unsure of the year, but 90's), it is a turbo 5 banger white block. He asked me today to help him out and I was stumped. He stated his car is making a grinding noise that sounded metal to metal and started quite suddenly. He stated it is at the rear of the engine (I had suggested both tensioners, and he replied they were both replaced at the last TB change). I don't know of anything at the rear of the engine that would do this (automatic that is shifting perfectly). I could only suggest the turbo (he doesn't think so), and perhaps the starter somehow not retracting enough to grind a little. He claims the car has started to burn oil (I'm thinking a venting system issue, but I'm also thinking "turbo"). Here's the part that threw me: Claims he was a quart and a half low, so added oil and the noise quit (but he only ran for less than a minute). When he restarted, the noise was back. I think this is "coincidental" and is the turbo. Any suggestions would be appreciated. I am posting on multiple forums as he is without a car (afraid to drive it), and desperate for a solution, or knowledge he can drive as is for now.
Jerry
Old 07-09-2010, 09:44 PM
I would think maybe starter is hanging up. But hard to say without hearing it.
Old 07-09-2010, 09:50 PM
checksix's Avatar
Thanks Tech, I think you are on a good track, and I'll forward your suggestion to take a good look at the starter!
Jerry
Old 07-09-2010, 09:56 PM
Hopefully it has not damaged the flywheel if it is the starter causing it.
Old 07-10-2010, 12:10 AM
checksix's Avatar
He quit driving it pretty quick when the noise started. I'll remind him to check the condition of the flywheel when he pulls the starter, That was a nice reminder to do just that, THANKS!
Jerry
Old 07-10-2010, 07:04 AM
Hopefully that is all it is.
Old 07-17-2010, 07:43 PM
checksix's Avatar
Default Fixed!
Tech, I just wanted to follow up and report back that your suggestion of the bendix as being the issue was RIGHT ON! A replaced started has resolved the issue.
THANK YOU!
Jerry
Old 07-17-2010, 09:01 PM
Glad all went well!!!
Nathan Forder
12-16-2014 01:05 AM
rhys_d1983
12-07-2011 11:09 AM
gordon368
09-01-2009 04:15 PM
Rascal2pt0
12-01-2008 10:26 AM
beach4me
04-06-2008 07:27 AM
Quick Reply: Metal to Metal sound in back of Engine
