POWER STEERING LEAK
POWER STEERING LEAK
I THINK I HAVE A POWER STEERING FLUID LEAK. SO MY QUESTION IS WHAT TYPE OF FLUID CAN I USE, AND HAS ANYONE ELSE EXPERIENCED THIS PROBLEM? WHERE SHOULD I LOOK, SO FAR IT LOOKS LIKE IT IS COMMING FROM ONE THE HOSESBECAUSE THEY ARE WET WITH FLUID BUT NOT SURE IF THIS IS THE SOURCE OF THE LEAK. OH YEAH ITS A 04 V70.
THANKS ROB
THANKS ROB
RE: POWER STEERING LEAK
I'm sure someone knowledgable will answer this, but I know I have seen threads on this topic. You might try searching. I vaguely remember reading a discussion about using Automatic Transmission Fluid vs Power Steering Fluid. (To answer your other question, I haven't experienced this problem.)
Get some Vavoline synthetic fluid with sealers.
http://www.valvoline.com/pages/produ...asp?product=22
This one.
Most likely it is leaking at the return hose at the pump or at the fluid bottle bottom hose.
This one.
andy2812
11-29-2005 11:09 PM
