Prop shft replacement on 1999 V70 XC - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 10-22-2010, 03:02 PM
Default Prop shft replacement on 1999 V70 XC
Newbie here with a question... I've got a 1999 V70 XC that needs to have the prop shaft replaced. I've done some researching and it appears that this is not a terribly difficult thing to do. Can someone point me to some instructions and/or pics? Also, any advice is very welcome!
Thanks!
Old 10-24-2010, 01:59 PM
Replaced the propshaft on my 98 V70R last year (center bearing completely gone) and the worst thing is paying for it! As I recall, a new one was $1300 +. I used a rebuilt one from Colorado Driveshaft for $475-$500 exchange inc. shipping. Service was prompt and the shaft has performed well. Removal and installation is straightforward - hex key bolts at both flange ends and 2 bolts at the center bearing bracket. Watch for different lengths or a color marking on the hex key bolts - apparently this how volvo does final balance. My were all the same so I didn't encounter this.
Old 10-25-2010, 07:49 AM
Thanks for the input. I actually already removed it yesterday (Sunday). It was exactly as you said. Once I figured out that it was a hex key (didn't have your response yet), I went a bought a 6mm hex socket and used my air ratchet. Not quite "easy-peasy", but not bad. I think my biggest mistake was not raising the car higher. When, and if, I buy a replacement, I will jack it up to the max height I can go.
So now I either have to get a replacement shaft, or peel off the "XC AWD" lettering.
Thread Thread Starter Forum Replies Last Post
2006 S60 2.5T AWD Prop Shaft Replacement Joker56 Volvo S60 & V60 6 04-20-2015 09:42 AM
1997 V70 R AWD Prop shaft problem LAD850 Volvo V70 4 09-09-2008 11:38 AM
Duo Prop Drive Trim apollo Penta 0 02-16-2008 07:55 PM
prop shaft bearing (U-joint) alireza1344 Volvo S70 2 10-22-2007 10:46 PM
AQ125A Engine & I/O Prop Problem jotrout Penta 3 06-26-2006 02:30 PM
Tags
1999, 6mm, bearing, drive, driveshaft, hex, prop, propeller, propshaft, removal, shaft, v70, v70xc, volvo, xc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
