power steering fluid
Old Sep 28, 2013 | 12:13 AM
sviana's Avatar
Default power steering fluid
I have a 2003 Volvo V70 2.4t. Can I use AFT Synthetic as power steering fluid?
Old Sep 30, 2013 | 10:51 AM
Georgeandkira's Avatar
Default Chf-11s
Hello, Use Pentosin CHF-11S in your system. It's transparent, pale green in color. It's the same synthetic stuff as Volvo branded fluid but less expensive.
In a pinch (trapped in Death Valley with a leaking power steering system, say) you could make due with synthetic ATF but you'd have to flush it out after you got to safety.
Use the proper stuff in the first place. AND, if your system is filled with red stuff or brown, burnt fluid, flush it until clear.
Central Hydraulic Fluid takes heat better than ATF. Power steering pumps are incredibly small, precision devices. Don't skimp on fluid. Kira
Old Nov 11, 2013 | 03:32 PM
Magic_Don's Avatar
Default Where can you find Pentosin CHF-11S
Where can you find Pentosin CHF-11S.
Don
westsacxj
Jul 13, 2017 07:50 PM
katiejoyful
Dec 12, 2007 04:49 PM
Majki
Jun 10, 2007 12:37 PM
reg
Mar 17, 2005 07:57 PM
Steamroll9
Jan 9, 2005 12:11 AM
