Timing Belt precautions!!
#22
#23
#24
RE: Timing Belt precautions!!
I thought about that. At one point I found step-by-step instructions with pics on how to do it on the web. I can't find those now. Do we have anything like that on the forum or should I just go out and find a service manual? It looked like the little markers on the gears and the block were easy to find.
#25
I found these instructions that seem pretty accurate.
http://www.volvoxc.com/resources/how...placement2.pdf
#27
For anybody that is thinking about doing this, FCP has a eBay sale going on for the kit. $116.99 with free shipping. I just bought it. Here are two more links to the others. It covers 01 to 04 V70 as well as other models:
http://cgi.ebay.com/ebaymotors/Volvo...mZ220292278092
http://cgi.ebay.com/ebaymotors/Volvo...mZ250267910193
I'll post links to other deals for the water pump, s-belt and tensioner if I find anything good, just as a reference for anybody else that wants to tackle this job on their own.
#28
I ordered the T-Belt, tensioner and pulley kit, also ordered the new S-belt tensioner. The s-belt I have is in great shape so I didn't see a need to change it. There's absolutely no cracking of any kind.
The only thing I need now is 30MM socket, torque wrench and I'll probably try to find the crank pully wrench that holds it in place.
I'm a little confused about one step though. The directions say remove the vibration damper with the special crank pulley took to keep it in place. The only thing I see on the schematics is the crank pulley which is bolted to the timing sprocket.
You don't have to remove the actual crank pulley do you? Is the vibration dampener the nut that goes on there? Is that tool used to move the crank or do you use the 30MM nut to do that? That's kinda where I don't get it.
#29
#30
Do you also use that tool to move the crank to align the markers or do you use the socket point for that? It looks like you can see the mark on the sprocket without taking the pulley off.
I don't have an air compressor or a impact wrench. I just bought a torque wrench though which I've been looking for an excuse to buy for a while. I have one of those old school long ones with the dial and it's been beat up.
#31
#34
#35
#36
Well, I got all of my parts for the job. Now I just have to figure out when I'm going to do it.
How many miles of life would you say is left in a belt that is in the same condition you pictured where it's safe to drive it, or should that belt be replaced ASAP?
#37
#38
Never hear squeeling. Actually, I just checked the weather this weekend and Sunday it's supposed to be 67 and cloudy, probably the last decent day around here to do it. After this week temps are going to start falling, so I'm planning on Sunday being the day. It should be the perfect day to work on a car.
I'm making sure I plan for the entire day for this. I know it shouldn't take long, but I'm **** about making sure everything is done right.
The 30 MM socket should be the only took out of the ordinary I need? I don't know the Torx bit size for the new s-belt pulley. I forgot to check before I left today.
#39
#40
In the instructions, it says "turn the eccentric".
What is the eccentric? The picture shows a bolt going through the tensioner, so I assume that's the bolt that holds it on, but is the entire center part of it the eccentric? Does that whole middle piece turn and then you tighten it down with the bolt?
