Groaning and roaring - wheel bearing?
I have a pretty loud groaning/roaring noise coming from my front end. It gets louder as I turn the wheel to the left. The pitch doesn't really change with speed, but it is the loudest between 25 and 55 mph. It also roars quite a bit when I brake. I've diagnosed bad wheel bearings before, but it was always a whirling noise more than a roar.
Do you guys think it may be the passenger side front wheel bearing? Any possibility it would be the diff/trans?
Thanks,
Thanks,
See post #2 in this link; that's how I used to diagnose wheel bearings when i was a tech.
https://volvoforums.com/forum/volvo-v70-13/2000-v70-wheel-bearing-hub-worn-out-36499/
