Where is it? Oil pressure sensor location.
RE: Where is it? Oil pressure sensor location.
The oil pressure sensor is located on the front of the engine about in the middle of the engine it has 1 wire going to it.Is there a special reason you are asking? Is the oil light on?If it is it is most likely not the sensor that is bad the car has low oil pressure.There are o-rings that go bad between the oil pan and the engine.They will need to be replaced.
MntnDewMan
04-03-2024 04:05 PM
bydand
2001-2013 model year XC70
46
10-23-2018 11:11 PM
brettboze
03-26-2012 06:25 PM
