2011 xc60 1 coil of spring like part fell down
I was driving on the road may be 20 miles /hr speed on my 2011 volvo xc60 suddenly semi circular part of the spring fell down from the car and made noise I emergency stopped the car and walk back on the road and seen a small semi circular black iron ring covered with black color, please advice me what do now? I drove the car to the home around 40 miles nothing I felt crazy , but what part is this, I am not at at all a technical person please guys help me , can drive my car, as today and tomorrow week end nobody opens the shop, but I have to travel again please help me
If you owned a Gen1 S40, you'd be used to this :-) I've had 3 of 4 break - all the same way - about 3 inches from the end, up near the mount. Like ES6T says you probably won't notice it unless you look. You would want to replace in pairs (ie both front or both rears) particularly on older cars to keep handling balance and get a proper alignment done following the install.
So there is harm If we drive the car with broken springs? I mean suddenly break another part while we going 50-60 miles / hour on free way and hit others ?? some thing may be possible like this ? or just it is useful for to take shock absorb??
Check out Volvo friendly sites like FCP Euro, EEuroparts, IPD USA etc. Tasca Parts (a dealer site) shows a replacement genuine Volvo spring at $120. You didn't mention which spring broke on your car but assuming its a front, then you'd need to remove the entire strut and disassemble using a spring compressor to swap the spring. Since you want to do both sides, its a good time to replace the struts as well. If your rear shocks are separate, you do need to unbolt the shock to allow the spring to uncompress so no special tools are required. Worst part of doing rear shocks is removing trim/covers etc to reach the top bolts :-) As always, any time you dissamble suspension parts its a good idea to get an alignment (particularly after doing struts). If I were to guess, I'd expect 1- 1.5 hours labor per wheel.
Assuming this is with Volvo spec'd hydraulic compressor. Would these fit?
https://www.autozone.com/loan-a-tool...sor/537058_0_0
