Tire Pressure Monitoring System (TPMS)
Old 08-28-2014, 08:01 PM
waadman's Avatar
Default Tire Pressure Monitoring System (TPMS)
Just an FYI for my XC60 buddies!
Taking a day road trip yesterday in our 2014 XC60 and an hour into our trip the TPMS and specifically the tire pressure warning light came up on the instrument panel. Just over 6K miles on our Nitrogen filled Pirelli's 20" Titania alloy wheels. Found a tire dealer who pumped Nitrogen so had him check for a leak (no leaks) and fill all the tires to spec which is 35 psi in the manual and on the door!
Drove off and the indicator never went away! Called my VOLVO dealer and they said that when inflating use between 36 and 38 psi otherwise the TPMS will continue to register low pressure! Got back home and took it into my local guy. He inflated to 37 psi on each tire. Drove out of his parking lot and the indicator light was gone
Life is Good
Squirrel24 (12-21-2022)
Old 08-28-2014, 10:58 PM
Joshinator99's Avatar
Life is Good
Wow, good info! Never would have guessed TPMS would go off at the CORRECT pressure...!
Nice color on your XC.
Old 12-08-2014, 02:59 PM
chippa8's Avatar
Yes good info indeed. I get the TPMS light while driving on the autobahn here in Germany and the dealer told me it was either bad sensors or my driving on the autobahn. I barely have 8K on the odometer so I figured the latter of the two because I frequently hit 120 MPH but am only going 30-60 MPH minutes later upon exiting. I will try this adjustment to see if it helps and repost. Thanks again for the info.
Old 12-13-2014, 04:15 AM
chippa8's Avatar
So I adjusted my tire pressure to 35 PSI on all 4 wheels two days ago since that's the factory setting for the stock wheels I have mounted. Took a trip to Belgium for beer and waffles and probably 30 minutes into the trip the stupid TPMS came on. I'll call the dealership again and see if they have any updates to getting newer sensors in yet.
Old 12-13-2014, 05:00 AM
waadman's Avatar
Default Bump Up the Pressure!
U have the same problem I stated in my original post! Try inflating to 37 psi as I stated vs the 35. I haven't had a recurrence of the issue since the 37 psi adjustment!
Good luck
Old 12-21-2014, 08:10 AM
chippa8's Avatar
Waadman, my bad, I must have missed the original details where you said your factory setting was also 35. I was thinking your different tire size may call for a different factory setting.
Anyway, I have good news! Yesterday morning I adjusted all four to 37 PSI and it worked! Took a 3 hr road trip (ea way) and not one warning light the entire way! Thanks again for this post.
Old 12-22-2014, 05:31 AM
waadman's Avatar
Default That's what this forum is all about:)
Chippa8,
Excellent news! Gotta love this forum and forums in general Bringing our experiences and solutions makes driving a pleasure
Keep on truckin!
Old 06-09-2015, 09:00 AM
Stevo Devo's Avatar
Default XC60 tyre pressure monitor
Hi Guys,
Have a late 2014 XC60 R-Design with 255/45/20 tyres in which the pressure monitor has come on. Started on Rear passenger side so inflated quickly to approx 41 PSI. Its still stayed on? Inflated all remaining tyres to approx this PSI but now all tyres are low on the dash display. Just looked on the inside of my car door and there is a PSI (39) for these size wheels. Should i inflate/ deflate to this exact PSI or is there a tolerance? I just want to get the light of my dash.
Any guidance will be appreciated.
Kind Regards,
Stevo
Old 06-10-2015, 05:42 AM
waadman's Avatar
Default Try a call to your dealer?
Morning, just read your post. If you check my original post on my experience it states that the tolerance the dealer reflected was 1 to 3 psi over the posted door or manual specs. That said and what you have done seems in line but with no results!
IF you bought the XC60 new then take her in and let the dealership resolve the issue! If not then make a friendly call to your service guy at your dealership and ask for their input in proper psi for the tires you are running! Try that recommendation before you decide to visit the dealership!
By the way I haven't had my original issue since the post
Old 06-10-2015, 09:58 AM
Stevo Devo's Avatar
Many Thanks for your response and guidance. I will keep you updated
Old 06-14-2015, 03:01 PM
Lutz's Avatar
I have a quick question. Just got a new 2015.5 XC60 but I can't find the TPMS in the settings. The menu option is just not there although the manual says that it should be there. I too have N2 filled tires, think that is standard these days. Does someone have the same issue, or could it be an option I don't have?
Thanks
Lutz
Old 08-14-2015, 07:09 AM
jdonde's Avatar
Default Same issue with 2015.5 S60
Thanks
Lutz
I have S60 (2015.5) and have the same issue. I was contacting Volvo and they told me that in cars made for USA there is no user available settings. Not clear how to reset the TPMS in case of tire replacement.
Tandy
06-29-2023 07:28 PM
FredRydr
11-13-2016 06:32 AM
strom19
02-20-2012 10:00 PM
Scott3985
07-17-2010 07:54 AM
wallst32
06-10-2008 01:40 PM
Quick Reply: Tire Pressure Monitoring System (TPMS)
