Tranny removal
Old 08-27-2011, 02:02 PM
Heath7's Avatar
Default Tranny removal
I've not had any luck locating a transmission removal tutorial. What is the best approach for removal? It looks like there is not enough clearance to slide it out the drivers side and the subframe won't allow it to drop out from below. Do I loosen the subframe and lower it while supporting the motor with a hoist or is it necessary to pull the motor/tranny assembly as a whole? I'm swapping in a used unit since I cannot shake the p0734 code. Any and all advice is appreciated.
Old 08-27-2011, 02:52 PM
VTBricked's Avatar
Drop the engine/transmission/subframe assembly. It sounds like more work, but it's really not, and less likely to put you in positions that are extremely difficult to work through. It's what I did with my '98.
It also gives you easier access to discover other parts that need replacement like mounts. (Which I did, too.)
Old 08-27-2011, 10:05 PM
Heath7's Avatar
Thanks!
Block91
2001-2013 model year V70
23
04-03-2020 09:53 PM
danborisuk
01-07-2012 06:27 PM
Heath7
09-25-2011 04:50 PM
Rammstein
12-11-2004 05:28 PM
ponies
09-10-2004 04:55 AM
Quick Reply: Tranny removal
