2006 XC70 Burning Oil - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 08-25-2011, 10:28 AM
Default 2006 XC70 Burning Oil
I have a 2006 XC 70 and it is burning about a quart every 2000 miles. It has 102,000 miles on it.
Volvo tells me that this is within acceptable rnage.
I find that hard to believe.
Any help or ideas?
Old 08-25-2011, 01:18 PM
Volvos rock's Avatar
Is it burning oil? ie smoking from the tailpipe, etc, or is it consuming oil? what have your oil change intervals been, 3k,5k,7500? What kinda oil do you use?
Old 08-26-2011, 07:10 AM
Default XC 70 2006 More Info on Using Oil
Thanks for your reply.
No smoke from the tailpipe.
I have the oil and filter changed every 7500 miles and use Mobil 1 or synthetic Castroil.
About two oil changes ago, the dealer screwed up and put in regular (non-synthentic) oil. They said it would make no difference for one oil change. MAybe it did?
This help?
I am not trying to diagnose as it is udner warranty (I had the 100,000 mile warranty) but just want to know if it is withini the acceptable range or is Volvo blowing smoke at me.
Old 08-26-2011, 08:14 AM
It would appear that it is consuming the oil and MAYBE sludge is forming. Wether or not Volvo says it is acceptable, It would not be to me. I would run shorter OCIs, for two or three changes, 3-5k. before the next oil change I would run a engine flush and change product through, I prefer Amsoil, but most dealers have BG products available that are good as well. after the two or three short oil change intevals see what happens.
Old 08-27-2011, 04:35 PM
Hi, my 2005 xc70 2.5T consumes a quart each 3,500 miles. In my case think is normal, the car goes always very fast (by freeways), part goes for the oil return pipe (a typical small leak that some day will fix), part by the intercooler (itīs a petrol turbo) and the remainder will consume it.
Run Castrol synthetic 5-30w A1 every 10.000 miles. I read cases of T5 or R that consumes even more going really fast, if itīs not your case you should be in the limit of the acceptable range…
Sorry for my Spanish English…
Thread Thread Starter Forum Replies Last Post
P0027, No oil pressure, burning LOTS of oil, rattle noise at start up. s70s70 Volvo XC90 3 12-26-2013 06:43 AM
Oil leak / burning Oil?? Serpentine belt, Radiator. Plz Help enigma9011 Volvo S70 7 09-01-2008 08:06 AM
Burning oil at idle mfiwd Volvo 850 11 03-01-2007 11:05 PM
940 Wentworth oil burning spandalax Volvo 240, 740 & 940 5 03-23-2005 10:49 PM
new s60 oil burning smell ignacio Volvo S60 & V60 1 09-17-2004 03:16 PM
Tags
2005, 2006, 2010, 2011, 70, burn, burning, burns, change, consuming, oil, v70xc, volvo, xc, xc70
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
