Crank.. crank then... start!
My 2000 XC70 with 142 K has had all the work it should have up to 130k... new AC all of it... cam sensor, thermo, and the ilst goes on. I love her but now I am collecting lights on the dash. Evidently the 02 sensor code and the Cata code are up and persistent... the SRS light just came on I want to keep and would, but now the starting is getting rougher and rougher with each passing day. Crank for 10 sec nothing... Crank for another ten and then she starts up put the revs alternate b/t high and low over 2k and under 1k. ? Do not want to (Cannot) spend the 2k for a new Cat and Sensors... anything else I could check?
TIA
TIA
And the hits keep on a rolling...
So after reading aroung last night I discovered that autozone can plug in and give me my error codes... Drum roll...
P1332, P)422
P0013, P0128 and P0116....
Not worried about the last two... can handle that. I have not cleaned out the throttle body... honestly do not even know where it is... will look. Can I clean it out or is this a tech deal?
The Cam code... I just put in a 200$ cam sensor... ?
Just priced a new universal Cata... 250 installed at a Shop...
SHould I bail on the old volvo and trade her in?
P1332, P)422
