Crankcase breather filter.
My xc has 140k and I am suspecting the flame trap setup is clogged.
What do you think about just adding a little crankcase breather filter to the line coming out of the crankcase, or just routing it to a catch can.
The OEM kit that ipd has is pretty expensive, so I was seeing if what I mentioned above would be an OK alternative.
Also, would the PCV valve not be in the system anymore if I added just a crankcase breather filter to the end of the tube coming out of the crankcase?[/align]
