Driveshaft noise?
Driveshaft noise?
I'm getting a clunking noise (sounds like it's under the back seat)when I occasionally start from a stop on my green volvo. Also ,when standing still, foot on brake and shifting from Drive to Reverse I get a similar noise but not as loud. The noise sounds similar to a rusted brake pad or shoe breaking away for a drum or rotor. If the consensus is that it is the driveshaft what steps can I take to verify that it is the culprit and what are the repairs recommended? Thanks in advance for any input.
RE: Driveshaft noise?
Thanks, Tech. The 3 motor mounts under the engine look fine (the passenger side was replaced last year as well as the top torque bushing) I lifted the car and had my wife shift from D to R frequently to see if there was excessive movement . All looked good. Any other ideas?
Thanks, Tech. I've been working on removing the driveshaft this afternoon and can't seem to get the rear end separated. I separated the front and after the 6 allen screws on the rear were removed, I yanked on the shaft pretty hard but it won't budge. Is it supposed to separate where the white dot is on the photo? I PB blasted it and will try again tomorrow.
[IMG]local://upfiles/1472/D22F3914B4894A21A87226C04E3B8547.jpg[/IMG]
Hey tech, I also have driveshaft related question. I just replaced turbo on my 01 v70XC and in process of removing it I took transfer case out and disconnected driveshaft to gain some room. I replaced turbo, smoke is gone but my driveshaft is very noisy now. I was wondering what could have gone wrong? Noise starts at about 40 mp/h and its unbearable, i cant drive the car. It was totaly fine before turbo replacement. Its too much coincidence that driveshaft is gonne all of a sudden. Are there any tips of driveshaft R&R?
MoneypitC70
2001-2013 model year XC70
10-26-2014 08:37 PM
