Fuel filler door
Fuel filler door
Quick question....
The fuel fillerr door on the wife's 01 XC 70 does not lock closed anymore. It used to lock within 10 minutes of locking all the doors, now it doesen't. Looks like the little lock plunger is sticking. Can anyone tell me
1. How to gain access to the plunger from inside the cargo area.
2. A good way to fit it or where to get a replacement.
Thanks,
Glenn
Thanks,
Glenn
RE: Fuel filler door
First check the relay which is located in the fuse panel at the L/R of the cargo panel. Hinge also might be broken, is there anything broken of the hinge near the fuel filler door? Do you have the feature where you unlock the filler door with a button on the headlamp switch panel?
