Grinding noise
Old 10-13-2011, 05:38 PM
lbrigner's Avatar
Default Grinding noise
About two months ago I purchesed a 2002 Volvo V70XC and i love the car. Today while driving a sudden grinding noise occured in the steering wheel and frount tires. It was so alarming i turned around and went home. After a little research I think it could possibly be the axil bearings but i dont know for sure. What is the best plan of action?
Old 10-13-2011, 06:01 PM
VTBricked's Avatar
The most common source of grinding is worn out brake pads grinding on the rotors. Jack up the front wheels and remove the tires to get a good look at the rotors and pads. If you must replace them, do both sides.
Wheel bearings generally have a long wearing out-to-worn out cycle, and typically make more of a roaring sound that is more pronounced when going around corners. The diagnosis for bad wheel bearings is play in the front wheel in both left-right and top-bottom wiggling. Jack the car up for this, but leave the lug nuts tight. Try to wiggle the tire toe-in and toe-out. Then try to wiggle the tire camber-in and camber-out. The play can be very subtle but should be the same for both wiggles.
I hope this helps. Pat yourself on the back already for not driving the car further and doing more damage. I recently bought an XC70 where the PO wore the rotors through the face and into the fins! He had to replace pads, rotors, AND calipers!
flyingcurtains
12-03-2007 01:43 PM
gooproduct
10-26-2007 07:29 PM
stu_cole
09-21-2007 06:22 PM
jabbo
08-01-2007 07:47 PM
rantiddlybobo
04-11-2004 12:47 PM
Quick Reply: Grinding noise
