How do you turn off "Time for Regular Maintenance" message?
How do you turn off "Time for Regular Maintenance" message that pops up every time I start the car?
I had an oil change only a couple of months ago and haven't driven much, so I want to wait another couple of months before the next regular maintenance.
The Volvo service station says they can turn the message off if I bring my car in, but I don't want to travel to the station just to do that.
Is there any way to turn the message off?
Fromm VolvoXC.com
XC SRI (Service Reminder Indicator) Reset Procedures
Resetting the service reminder indicator (SRI)
Hint: The indicator can also be reset using VADIS vehicle communication.
Resetting the Service reminder indicator (SRI), model years -2001
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The lamp remains lit for 120 seconds when the ignition is switched on. Note! If the lamp flashes, it may be because one of the service parameters has not been programmed.
Proceed as follows to reset the service reminder indicator (SRI):
* Ignition position I
* Press and hold in the reset button for the trip odometer
* Ignition position II
* The service reminder indicator (SRI) starts flashing when the reset button for the trip odometer has been pressed for 10 seconds
* Release the reset button for the trip odometer within 5 seconds. The instrument gives an audible signal when resetting has succeeded. Note! If the trip meter reset button is not released within 5 seconds the indicator is not reset. However the indicator will stop flashing.
Resetting the service reminder indicator (SRI), model years 2002-
The service reminder indicator (SRI) informs the driver that it is time for the car to be serviced. The text message is displayed for 120 seconds each time the ignition is switched on. Proceed as follows to reset the service reminder indicator (SRI):
* Ignition position II. Note! Turn the key to position II within 2 seconds.
* Hold the reset button for the trip meter pressed in until the original value has been reset. Note! For all vehicles from the 2003 model year a general yellow lamp will light when the reset button must be released.
* Release the reset button for the trip odometer within 4 seconds. The instrument gives an audible signal when resetting has succeeded
* If the trip meter is already reset the reset button should be held in for a minimum of 10 seconds and a maximum of 14 seconds. Note! If the reset button for the trip odometer is not released within 4 seconds, the service reminder indicator (SRI) is not reset.
JoAna (06-24-2020)
Berndy, time to google "reset service light volvo s80 2009". OK on second thought, don't bother... just use this link
How To Service Light Reset in Volvo S80, V70, XC70 (2006 on)
