Looking for help with what to do with my car.
Old 07-01-2014, 02:29 AM
Austin's Avatar
Default Looking for help with what to do with my car.
Hi I've joined this forum in hopes that I could get some help deciding what to do with my car. I bought a 99 cx70 at the beginning of the year and spent 2300 buck after 2 weeks the car started to misfire on the 4th cylinder and so I went through the basic checks hoping it would be an easy fix and it wasn't one of the exhaust valves had broke so i tore the car apart and spent 6 days fixing it to have my cousin try and be helpful and set the timing 180 degrees off and turned the key not thinking and most likely bent a good chunk of the 20 valves. is it worth putting another 600 bucks and 6 days into fixing it or should i just sell it as is. any help would be awesome.
Old 07-01-2014, 05:58 PM
pkrface's Avatar
The only way to look at this is how much can you get for it as it sits and how much car does that and $600 buy you? If the answer is less car than what you would have spending $600 on the car you have then you have your answer.
Old 07-23-2014, 06:39 AM
Welcome to the forum
New Member is a place to introduce yourself and your car but your cars area is where to ask for help. You are also much more likely to get help when posting questions in your cars specific area. Post moved to correct area.
mal81394
02-27-2015 06:14 PM
El_Chapusca
09-19-2010 04:10 PM
Michael7272
01-10-2009 01:47 PM
turbovolvo
09-14-2006 08:40 PM
Quick Reply: Looking for help with what to do with my car.
