P0101 Mass Air Flow
P0101 Mass Air Flow
Hi Guys, I'm having P0101 Issues on My 2006 XC70. Seems to be throwing P0101 Codes. I've tried to clean the Mass Air Flow but problem persists.
Now On Occasion Car Has rough starts and looks like it wants to die at start up.
Iv pulled out the Freeze Frames for a Couple of incidence of the DTC. Any Ideas?
I Don't want to debug by replacing the MAF as the part costs about 400$ . So I might start off by replacing Spark plugs and moving onwards from there.
PID Description Value Units
0x02 Freeze frame DTC P0101 -
0x03 Fuel system status Closed-loop, using oxygen sensor feedback to determine fuel mix -
0x04 Calculated load value 10.2 %
0x05 Engine coolant temperature 188.6 F
0x06 Short term fuel % trim - Bank 1 23.44 %
0x07 Long term fuel % trim - Bank 1 7.03 %
0x0A Fuel rail pressure (gauge) 67.88 PSI
0x0C Engine RPM 1289 RPM
0x0D Vehicle speed 34.18 MPH
0x0E Ignition timing advance for #1 cylinder 0.5
0x0F Intake air temperature 17.6 F
0x10 Mass air flow rate 0.6 lb/min
0x11 Absolute throttle position 13.33 %
0x1F Time since engine start 1574 sec
0x2E Commanded evaporative purge 0 %
0x33 Barometric pressure 14.65 PSI
0x42 Control module voltage 14.59 V
0x43 Absolute load value 13.33 %
0x44 Fuel/Air commanded equivalence ratio 1
0x45 Relative throttle position 1.96 %
0x46 Ambient air temperature 14 F
0x47 Absolute throttle position B 13.33 %
0x49 Accelerator pedal position D 10.59 %
0x4A Accelerator pedal position E 10.2 %
0x4C Commanded throttle actuator control 3.14
0x04 Calculated load value 12.16 %
0x05 Engine coolant temperature 172.4 F
0x06 Short term fuel % trim - Bank 1 9.38 %
0x07 Long term fuel % trim - Bank 1 6.25 %
0x0A Fuel rail pressure (gauge) 43.51 PSI
0x0C Engine RPM 676.75 RPM
0x0D Vehicle speed 0 MPH
0x0E Ignition timing advance for #1 cylinder 4.5
0x0F Intake air temperature 55.4 F
0x10 Mass air flow rate 0.35 lb/min
0x11 Absolute throttle position 12.55 %
0x1F Time since engine start 335 sec
0x33 Barometric pressure 14.5 PSI
0x42 Control module voltage 14.4 V
0x43 Absolute load value 15.69 %
0x45 Relative throttle position 1.57 %
0x46 Ambient air temperature 37.4 F
0x47 Absolute throttle position B 12.55 %
0x49 Accelerator pedal position D 7.84 %
0x4A Accelerator pedal position E 7.06 %
0x4C Commanded throttle actuator control 1.96 %
