timing belt - bent valves
Here's the story. Picked up the car ('98 V70XC) a year and a half ago with 109000 miles. It looked very clean and maintained. There is a Volvo dealer service sticker indicating that the timing belt was changed at 70000. At 130000 in the middle of nowhere, but thats a whole story in itself, I park the car and hear a rubbing noise and get out and open the hood with the engine idling. Clearly the timing belt cover is being rubbed by the belt. In the dark I grab the cover and pull on it a little to see if the noise quits and to my amazement the front of the cover pulls back and reviles the timing belt which then falls off the intake pulley which off course results in the engine shutting down. The belt was being held on by the cover and it milled away at the inside surface until it broke through when I handled it. Question is would the valves bend at idle when the belt came off? The car is being transported to my home so I haven't taken a good look at it but I'm assuming that the tensioner failed.
RE: timing belt - bent valves
Here's the follow up and a question.
Knowing that this is an interference engine I still thought I'd put the belt back on and take a compression test.
Result compression in all cylinders: 175, 160, 175, 170 and 165.
I'm thinking that with the car parked and engine at idle maybe I dodged the bullet. I can see that if the same thing had happened while driving the drivetrain would continued to spin the engine.
Here is the question on the '98 does the crank pulley have to come off to replace the belt. I've changed the belt on an 850 and although tight with a little presto changeo it comes of the crank. I'm not able to preform any magic on the V70XC.
[IMG]local://upfiles/7685/B2B5122594D442CCAE72F15155B48D8F.jpg[/IMG]
[IMG]local://upfiles/7685/C003EE05EE494B6BB1A7B2FB9E48DE65.jpg[/IMG]
texan_176
10-06-2012 09:02 PM
