Transmission fluid checking
Old 01-15-2007, 07:26 PM
Psaboic's Avatar
Default Transmission fluid checking
Folks,
Correct me if I am wrong. Theproper way to check the transmission fluid in our cars is with the transmission fluid at operating temperature, and the engine idling.....right? That is what I have always been taught to do.
I was told by a technician at the dealer today that you check the fluid with the fluid at operating temperature but with the engine OFF.
Please tell me which is correct. I believe the fluid in our XC-70 is a bit low and I want to get a proper reading.
Thanks,
Glenn
Old 01-15-2007, 09:35 PM
Default RE: Transmission fluid checking
With the car running!!
Old 01-16-2007, 12:40 AM
Psaboic's Avatar
Running is what I thought, but this guy was adamant that the engine should be off........go figure. Anyway, I checked the fluid with the engine running and it was indeed a little less than a pint low from when I changed the fluid two weeks ago.
Glenn
bgilliam
08-15-2013 10:59 AM
jbuggin71
06-29-2011 11:53 PM
ewgoforth
11-04-2010 03:35 PM
mjl
01-12-2009 05:01 PM
syzygy66
08-03-2005 09:30 PM
Quick Reply: Transmission fluid checking
