Windshield Rubber Trim
You can get the trim from the dealer but you will pay over $200.
There's a post on the VolvoXC.com Site on a repair for this. Windshield Trim Rubber Repair
I ordered the Corner Pieces and spare clips from IPD and just installed this. I couldn't find the tubing like 9Dawgs used on his repair over at the VolvoXC site post. So used a rubber Garage Door seal from the Home Depot and cut it to the needed width.
These are for the Volvo V70 or XC70 Windshield molding clips (6), corner trim pieces (1) Left, (1) Right and spare retaining clips (4) 2 extras. Purchased over at The Volvo Parts, Accessories and Performance Specialists Since 1963
120131 Corner Trim Left (1)
120132 Corner Trim Right (1)
120630 Clips Windshield Trim (6)
120133 Trim Clip general (4)
The Trim I cut to 5/8 inch width, could have cut to 1/2 inch the windshield wiper touches on the left passenger side. I removed the old rubber from the trim strips using a razor knife. Then glued the new on with contact adhesive. After the trim was installed I could see the clips under the trim easily. I cut an additional strip from the rubber seal and tucked it in under the trim to close this out. That may interfere with the water draining down the side of the windshield but it shouldn't cause a problem. I'm not sure how UV resistant the rubber seal is going to be. Cost on it is about $9 for a 9 ft length which is more than enough to replace both sides.
Windshield Side Rubber Trim Pieces
Nice job of repairing the windshield trim. My question is: Are these pieces for appearance only? I don't think the windshield will leak, correct? The windshield is sealed by the gasket between the windshield opening and the glass, correct?
I would like to fix the trim rubber and the corner pieces like is shown here but just want to know whether it will develop a leak as the trim rubber piece slowly disappears.
Thanks
Thanks
Nice job with the garage door seal. I've pulled a lot of those out on cars that come out of Florida for the same reason that you replaced yours. I do, however, replace the corner pieces. I have found that the S60 and XC70 are the same part numbers:
End Piece 8663896
End Piece 8663894
End Piece Retainer 3521768
Molding Clip 30678009
End Piece 8663896
End Piece 8663894
