Sponsored by:
Sponsored by:
Running on 5 cylinders
Old 11-22-2013, 03:58 PM
williala's Avatar
Default Running on 5 cylinders
I decided to check the condition of my spark plugs today, (96,000 miles) and took out #5 and #6 plugs and they looked great. Very clean.
I put them back in, made sure the coil packs were well seated and upon startup, a very bad misfire occurs.
Took it to Autozone for a OBDII scan and came back with thee codes:
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P050b
Any idea what would cause a misfire code on all cylinders?
Old 11-22-2013, 04:50 PM
williala's Avatar
An update:
I disconnected the wiring from the coil packs on #5 and #6, and the engine runs the same. So I guess both cylinders are not firing.
2008 XC90 3.2
Old 11-22-2013, 09:30 PM
williala's Avatar
It turned out that I was numbering the cylinders wrong, it was #1 and #2 cylinders, not #5 and #6. Anyway, I had the coil pack wires crossed and that was the problem.
Old 11-22-2013, 10:19 PM
damien360's Avatar
damn if i wouldve seen this post earlier i couldve told you what that problem was in the first post. ive taken those engines apart many many times and the coils get switched because of the way they route.
Old 11-23-2013, 09:44 AM
williala's Avatar
damien360
I wish you would have seen it earlier too. It was a depressing few hours until I figured it out. You are right about the wiring route, I could have sworn on a Bible I had them on right because of the way the wires had taken a set. Live and learn. Thanks
wags70ss
06-29-2011 05:09 AM
MYS60T
11-29-2008 09:16 PM
Alden
08-31-2008 11:06 PM
waxk
03-07-2006 03:24 PM
manicmechanic
03-04-2005 06:55 PM
Quick Reply: Running on 5 cylinders
