Sponsored by:
Sponsored by:
2006 xc90 4.4 power steering pump
Old 03-14-2017, 10:04 PM
green2man0's Avatar
Default 2006 xc90 4.4 power steering pump
Does anyone know if the power steering pump from any other year or model will interchange with a 2006 xc90 4.4? It seems to be a rare part. Volvo cost is 475-750 and all the rebuilt or aftermarket ones don't seem to have much information about them.
Old 03-14-2017, 10:07 PM
ES6T's Avatar
You're limited to any year 4.4
Old 03-14-2017, 10:11 PM
green2man0's Avatar
so the 07 08 09 4.4 xc90 will fit the 06? The reason I ask is they have different part numbers and I'm not familiar with the part enough to know if the mounting is the same
Old 03-15-2017, 05:04 AM
ES6T's Avatar
They should but let me double check. Maybe they changed something
Old 03-15-2017, 12:42 PM
ES6T's Avatar
I'm showing all XC90 V8s to have the same pump.
Old 03-15-2017, 08:58 PM
green2man0's Avatar
Thank you, I have one other question?. I bought the car in December and was waiting till spring to give it a full service. Since I'll be replacing the power steering pump I was going to do the idler pulleys at the same time. From searching the diagrams I see 2 pulleys on the block and one on the belt tensioner. From looking at the diagrams all 3 appear to be the same pulley. Is the pulley on the tensioner the same as the 2 on the block?
I'm hoping so because the tensioner is about 400-500 and the bearing is 50
Old 03-16-2017, 05:12 AM
ES6T's Avatar
I'm not sure because Volvo doesn't sell just the pulley for the tensioner, it comes as an assembly.
Old 06-08-2017, 06:56 AM
MartyinGA's Avatar
Curious if green2man0 was successful. Replaced a 2005 XC90 4.4 PS Pump due to hard steering and noises during cold starts. Turns out that wasn't the problem - same symptoms after replacement. So it is something 'else' in the belt train or hydraulics. Scouring the Forum to see if any others had a similar problem.
timothyha22
01-23-2018 01:32 PM
green2man0
03-26-2017 10:47 AM
Csaba
07-05-2012 11:10 PM
Bandac2000
09-15-2011 05:17 PM
katiejoyful
12-12-2007 04:49 PM
Quick Reply: 2006 xc90 4.4 power steering pump
