Check Stop Lamp - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 03-25-2011, 12:18 PM
Default Check Stop Lamp
I just bought a used 2003 XC90 T6. I have a small problem that just started two days ago... When i step on the breaks, I get a message "Check Stop Lamp" I've read some forums and it says to replace the break relays. Is that correct? is there a way to find out if thats the issue or something else. Please help.
Old 03-27-2011, 12:18 PM
ed7's Avatar
ed7 ed7 is offline
First, check for a bad bulb.
Ed
Old 03-27-2011, 12:42 PM
Bad bulb or a loose bulb. Volvos (at least all of mine) seem to have this loose bulb issue more often than not.
Old 03-28-2011, 08:27 AM
Quote:
you probably have a burned out tail-light could be the left could be the right or the high mount it could be 1 of them 2 of them or it could be all 3 before you go replacing brake relays check your stop lamp. Word of caution when going to fourms/ garages for help. No matter what they tell you start with the solution that costs the LEAST! amount of money then work your way up.
Old 01-05-2012, 05:27 PM
Its the bulb! 100%
Thread Thread Starter Forum Replies Last Post
2005 xc 90 check stop lamp spikedmd87 Volvo XC90 2 08-23-2011 06:56 AM
Bulb Failure Position Light & Check Stop Lamp sas80 Volvo S60 & V60 8 08-11-2011 08:57 AM
2004 S60 2.5T CHECK STOP LAMP Issue! AHHH!!! murphysmotors Volvo S60 & V60 11 07-15-2011 11:55 PM
2003 XC90 T6 - Check Stop Lamp ankitjuthani Volvo XC90 0 03-25-2011 12:28 PM
Tailgate lock and check stop lamp fault vwbusman Volvo V70 2 10-28-2009 08:12 PM
Tags
2003, 2004, bad, bulb, change, check, forums, high, lamp, message, messages, mount, stop, volvo, xc70, xc90
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
