Sponsored by:
Sponsored by:
Engine oil on top of the transmission?
Old 12-01-2007, 09:27 PM
m1964's Avatar
Default Engine oil on top of the transmission?
noted recently some engine oil (at least it does not smell like transmission oil) on top of the transmission.
I do not see any leaks from the engine -any onehad anything like that?
The car is XC90 V8 with 27000 miles.
Old 12-01-2007, 09:56 PM
atornquist's Avatar
Default RE: Engine oil on top of the transmission?
If it is on top of the transmission I can't see how it can come from the transmission. Assuming you had your last oilchange performed by the dealer, I would say this is just an oil spill from your last service butsince your 30K service due soon, it wouldn't hurt notifying the service department (get in in writing on your service request). Probably nothing to worry about
Old 12-02-2007, 08:33 AM
Maybe rear cam seal leaking.
It does a good job of hiding behind stuff leaking down.
Old 12-02-2007, 04:59 PM
m1964's Avatar
ORIGINAL: tech
tech, could you elaborate on that? Where shouold I look?
Thank you.
It can't be an oil spill-oil filler cup is on the opposite side of the engine...
Old 12-02-2007, 08:24 PM
Is it towards the back of the engine?
If so the upper engine mount bracket hides the Cam sensor where it might be leaking from.
Old 12-03-2007, 08:52 PM
m1964's Avatar
Thank you-I will look on weekend-it gets dark early now, by the time I'm home it's too dark. I don't think a flashlight will do, I need sunlight.
Old 12-18-2007, 11:38 AM
just curious,
what was the outcome, i am experiencing a similar problem
thanks.
Old 12-23-2007, 06:24 PM
m1964's Avatar
ORIGINAL: xc90guy
just curious,
thanks.
I am not sure what it is-
I am trying to get a volvo field tech to look at it.
firebirdparts
07-08-2014 01:05 PM
dhodge
09-23-2010 06:09 PM
pacificnw2011
09-05-2010 07:42 PM
97850glt
Engine & Internal
07-30-2010 09:24 AM
Lukeman
01-24-2010 08:01 PM
Quick Reply: Engine oil on top of the transmission?
