Sponsored by:
Sponsored by:
Question about timing belt replacement method
Old 10-24-2012, 09:52 PM
chuckketcham's Avatar
Default Question about timing belt replacement method
The Volvo instructions for replacing the timing belt state that before removing the old timing belt you must rotate the crankshaft until the marks on the camshafts line up with the notches on the top timing belt cover.
But what if I were to first mark the old timing belt, camshaft gears and crankshaft with white-out, remove the belt, transfer the timing belt marks to the new belt, and install the new-belt making sure to line up my marks? Would it still be necessary to rotate the camshaft before-hand to line up the built-in camshaft marks with the notches in the top timing belt cover? It seems to me this would be unnecessary since all you care about is keeping the camshafts and crankshaft in time with each other. The white-out method should guarantee that, right? Or am I missing something? This is my first timing belt change so I want to make sure I don't mess it up.
Thanks.
bcolins
2001-2013 model year V70
10-28-2013 10:55 AM
liweih21
06-05-2013 04:40 PM
reidb1
07-08-2008 01:25 PM
daver80
03-17-2008 04:34 PM
jguerra3235
03-25-2007 10:20 AM
Quick Reply: Question about timing belt replacement method
