Rear wiper arm removal - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 12-19-2010, 07:33 PM
Default Rear wiper arm removal
The rear wiper blade on my 2005 XC90 T6 was torn and when I went to remove the wiper, the tabs that hold the wiper to the arm broke. Yeah I am extremely happy about that. So I read a post regarding arm removal (pry up and out) that did not work. I need your advice guys/gals! Anybody know how to remove the rear wiper arm? I know if I go to the dealer they will think I am Santa Clause with a bag full of money to be delivered to them....Not.
I need your help.
Thanks in advance
Jeff
Old 12-19-2010, 10:41 PM
Just had my Volvo dealer replace the rear wiper. It is one unit with the wiper arm. $24 out the door. Not worth messing with on your own for that price.
Old 12-22-2010, 01:17 AM
I had the same problem. Found these awhile back. Unfortunately, you might have to register as a user (you can use an alias email to register) to view the doc. If it doesn't work, ping me and I can email a .pdf to you.
http://www.justanswer.com/view_image...wiper_0000.jpg
Old 12-22-2010, 07:58 AM
between the LV on your lift gate emblem that says volvo you will see where the wiper is attached to the motor basically pop off that peice of plastic there and use a 10 mm wrench to remove the arm from the motor assembly.
Old 12-24-2010, 12:15 PM
ditto above. Take the nut off and just slowly pry the arm off. It is just pressed on when you tighten the nut down.
Old 01-03-2011, 09:43 AM
Quote:
yeah you may need to jiggle and play with the arm a little bit to get it off but its really easy and will save you getting robbed for parts and labor.
Thread Thread Starter Forum Replies Last Post
7/9 - Package Deal - Red/Clear Tail lights, Wagon Rear Spoiler, Grab Handle,Wiper Arm greenman86 For Sale / Trade 0 03-11-2015 04:29 PM
Rear Suspension Bushing removal from trailing arm VTBricked Volvo 850 4 06-24-2009 09:15 PM
windshield wiper arm removal Ashokan1 Volvo 240, 740 & 940 3 01-29-2009 01:37 PM
01 Rear Wiper Arm bent HummerGuy Volvo V70 2 12-28-2008 02:37 PM
I need a rear wiper arm for a 2003 V70 03v70 Volvo V70 1 01-18-2008 09:32 PM
Tags
arm, gate, install, installing, lift, motor, rear, replace, replacement, unit, v40, v70, volvo, wiper, xc90
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
