Sponsored by:
Sponsored by:
Rear wiper arm removal
Old 12-19-2010, 06:33 PM
jeffrodw's Avatar
Default Rear wiper arm removal
The rear wiper blade on my 2005 XC90 T6 was torn and when I went to remove the wiper, the tabs that hold the wiper to the arm broke. Yeah I am extremely happy about that. So I read a post regarding arm removal (pry up and out) that did not work. I need your advice guys/gals! Anybody know how to remove the rear wiper arm? I know if I go to the dealer they will think I am Santa Clause with a bag full of money to be delivered to them....Not.
I need your help.
Thanks in advance
Jeff
Old 12-19-2010, 09:41 PM
stonepa's Avatar
Just had my Volvo dealer replace the rear wiper. It is one unit with the wiper arm. $24 out the door. Not worth messing with on your own for that price.
Old 12-22-2010, 12:17 AM
herrvolvo's Avatar
I had the same problem. Found these awhile back. Unfortunately, you might have to register as a user (you can use an alias email to register) to view the doc. If it doesn't work, ping me and I can email a .pdf to you.
http://www.justanswer.com/view_image...wiper_0000.jpg
Old 12-22-2010, 06:58 AM
04XC90T6AWD's Avatar
between the LV on your lift gate emblem that says volvo you will see where the wiper is attached to the motor basically pop off that peice of plastic there and use a 10 mm wrench to remove the arm from the motor assembly.
Old 12-24-2010, 11:15 AM
upsidedown's Avatar
ditto above. Take the nut off and just slowly pry the arm off. It is just pressed on when you tighten the nut down.
Old 01-03-2011, 08:43 AM
yeah you may need to jiggle and play with the arm a little bit to get it off but its really easy and will save you getting robbed for parts and labor.
greenman86
03-11-2015 03:29 PM
VTBricked
06-24-2009 08:15 PM
Ashokan1
01-29-2009 12:37 PM
HummerGuy
12-28-2008 01:37 PM
03v70
01-18-2008 08:32 PM
Quick Reply: Rear wiper arm removal
