removing pins from wiring harness
So I have the left blinker/driver door open issue due to a broken wire. It's the back wire right at the harness that clips to the door. Needs to remove the remnants of the wire and the pin. Any help on how to get the pin to release?
I did the job about an hour ago. I used a needle nose and yanked like a butcher. I then used a generic piece from a speaker set and crimped it on to the black wire and pushed. no clicking, but I think it will hold. hope someone has a better solution.
here are two links that don't have your answer, but may help others.
http://forums.swedespeed.com/showthr...29#post3091329
https://volvoforums.com/forum/volvo-...problem-81755/
I've searched for a picture of what these specific pins looks like to see where the catch is, but I just can't get the right combination of search terms. Plus, with all of this manhandling, I may end up needing a new one. Can anyone point me in the right direction?
