Sponsored by:
Sponsored by:
05 xc90 T6, turn signals reversed......
Old 09-29-2016, 02:01 PM
cabassist803's Avatar
Default 05 xc90 T6, turn signals reversed......
Hey all. New here, and I'm having a crazy problem. I local mechanic recently broke the end of my signal stalk so I had ordered an OEM replacement from fcp. Well, it just got here today and replacing it was simple enough, but now the problem is strange. When I push up on the turn signal to go right, nothing happens. When I push down to signal left, the right starts blinking. Exterior lights correlate. Everything else on the stalk works as it should.
The question is this. Why is it doing this? Faulty part? Improper installation?
Old 09-29-2016, 03:05 PM
firebirdparts's Avatar
Sounds like the plug was assembled incorrectly to me. Maybe you can compare wire colors with your old plug.
Old 09-29-2016, 03:14 PM
That would make sense, but these plugs aren't really traditional. You simply unscrew the 2 small Philip's heads and slide the switch out. Then slide the new one in. Really idiot proof for the most part. Could it be that the steering wheel wasn't perfectly straight, and that caused the issue?
Christian Jordan Rayburn
10-01-2015 09:46 AM
studd34000
01-09-2007 10:01 PM
RedBrick
09-16-2006 09:06 PM
WagHag
06-26-2006 09:43 PM
bpeabody
08-02-2004 12:16 AM
Quick Reply: 05 xc90 T6, turn signals reversed......
