Sponsored by:
Sponsored by:
Volvo XC90 oil leak problem
Old 03-20-2015, 10:59 AM
Erikas's Avatar
Default Volvo XC90 oil leak problem
Hi there,
I bought a 2005/12 Volvo XC90 2.4 D5, and I have some problems with it,
in the second foto I circled the thing (whatever it does, if you could please explain). The problem is that it leaks oil there, I bought a new gasket under the valve cover and im on my way to change it. So, will the gasket fix my problem or does the thing that I circled should do or go anywhere? In the second photo I also circled the unknown thing to me. Does it have any function? Maybe there's something missing? Please respond. Thanks.
P.s do I need a computer to adjust my valves after I take the cover off? Because I want to change the gasket myself.
Attached Thumbnails Volvo XC90 oil leak problem-20150311_115537_richtone-hdr-.jpg   Volvo XC90 oil leak problem-20150311_115524_richtone-hdr-.jpg
Old 03-21-2015, 10:26 PM
scotsborn's Avatar
The oil leak appears to be the valve cover. No, you don't need a computer to adjust your valves after the cover comes off.
Please take a photograph from further away as I cannot get a good look at the part and where it is located in the engine compartment.
Old 04-14-2021, 02:34 AM
Uga1995's Avatar
Default Oil leak
Hi
Did you manage to fix the problem?
I got exactly same issue
Vintage
09-14-2015 06:51 AM
imon_2nd
07-23-2010 02:50 PM
nonsense619
01-30-2009 08:02 AM
JBVolvo
04-06-2007 01:55 PM
rob960
05-17-2006 11:05 PM
Quick Reply: Volvo XC90 oil leak problem
