Sponsored by:
Sponsored by:
Xc90 03 D5AWD WON'T START
Old 01-06-2013, 11:16 AM
PaddyEvans's Avatar
Default Xc90 03 D5AWD WON'T START
Hi
Got an 03 D5 which won't start but is turning over makes a lot of clicking noises and cd player goes a bit mad for a while then beeps 3 times. I've tried jumping and disconnecting battery but problem remains. Approximately 10 minutes before problem happened I started and drove it to move around drive.
Any advice greatfully received as has caused no end of problems including new (reconditioned after 75k miles) engine at 112,000 miles a few months ago. Just been serviced and cost another grand but has been running well for last few weeks.
Old 01-07-2013, 03:34 AM
ARchitects's Avatar
Originally Posted by PaddyEvans
Hi
Why don't you post your thread on Volvo Forum UK, you will probably get a better feed back because members on this forum are mostly Americans, and as you know diesel engine XC90s are not available in the U.S
Old 01-07-2013, 10:01 AM
schumicat's Avatar
clicking usually means battery is not strong enough to turn starter. try fully charging the battery with a battery charger. if battery is really weak, sometimes jumping won't work unless you leave the cables connected for some time (like half hour) before trying to jump it.
Gustav
11-11-2017 01:01 PM
volvoralph
07-19-2016 04:19 PM
exotek
11-11-2008 09:32 AM
Edashcash
06-08-2008 12:39 AM
Quick Reply: Xc90 03 D5AWD WON'T START
