XC90 B6294T Timing Belt Replacement Procedure
RE: XC90 B6294T Timing Belt Replacement Procedure
Thanks for the reply.
I already purchasedthe programand for some reason I could never get it to work. It only booted up on a laptop and only some of the proceedures were there. To me I though I got ripped-off. Paid $25 for it. Nothing about the timing belt!
Anywho, someone emailed me and said ALLDATA.com is good!
Thank you for your time!
Bill
Bill
When you set the Vadis up you might not have activated everything.
Go back in as admin and make sure for the screen name and password you can up with has everything selected. If you did not select all then there will be alot of info missing.
You already have the program I cannot see you spending more $$$ if you already have everything you will need.
If you need more help setting it up you can PM me tomorrow and I will try to help you get it sorted out.
csb
07-29-2010 08:21 AM
