What is the tire width recommended for this wheel from an 850 Turbo? - Volvo Forums - Volvo Enthusiasts Forum
Thread Tools Search this Thread
Old 10-05-2016, 06:10 PM
Luke Woessner's Avatar
Exclamation What is the tire width recommended for this wheel from an 850 Turbo?
http://volvoforums.com/forum/attachm...1&d=1475705344
I'm upgrading from my heavily worn steel wheels and these are cheap. What tire would you recommend?
-Thanks!
What is the tire width recommended for this wheel from an 850 Turbo?-wheelman.jpg
Old 10-06-2016, 06:50 PM
If they are 16"x6.5" like the newer Perfos, the factory tire size is 225/55R16, I believe. Those should work quite well.
Old 12-07-2016, 04:37 PM
Moderator
OEMs should be 16 x 6.5 with a 43 ET (offset) stamp. Factory tire for the 850 Turbos with the Columba's was 205/50-16 (the standard Cetus 15 inch rims came with 195/60-15s). You can also go with a 215/50-16 if they are easier to find.
Thread Thread Starter Forum Replies Last Post
Whats the best width and offset for rims on a 99 s40 t-6 ITS ME DAVID Wheels, Tires and other Exterior 2 09-12-2009 10:30 AM
wheel width for stock 6 spoke 15" 94 + options rich nc Volvo 850 1 03-19-2009 06:26 PM
Running rich... Injector pulse width? / MAF signals? gl1970 Volvo 240, 740 & 940 3 08-28-2007 03:40 PM
Maximum wheel width and diameter? nightlog Volvo 850 3 06-24-2007 09:33 AM
Width and Offset for Wheels on a 2000 V70XC AWD? ThE B MaN Volvo V70 4 01-09-2006 04:05 AM
Tags
5 spoke, 850, tire, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
