Volvo S60 C70 S70 V70 XC70 S80 XC90 Ignition Coil Pack 1999-2007
Accessories
  • Accessories - Volvo S60 C70 S70 V70 XC70 S80 XC90 Ignition Coil Pack 1999-2007 - New - 1999 to 2004 Volvo C70 - 2001 to 2005 Volvo S60 - 1999 to 2000 Volvo S70 - 1999 to 2004 Volvo V70 - Washington, WA 98170, United States
    $66
  • Location Washington, WA, 98170, USA
  • Condition New
  • Compatibility
Make Model Year
Volvo C70 1999 - 2004
Volvo S60 2001 - 2005
Volvo S70 1999 - 2000
Volvo V70 1999 - 2004
ENA Set of 5 Ignition Coil Pack Compatible with Volvo S60 C70 S70 V70 XC70 S80 XC90 Replacement for C1258 UF341
Compatible with:
Compatible with these L5 2.3L Engine
  • 1999-2004 Volvo C70
  • 2001-2005 Volvo S60
  • 1999-2000 Volvo S70
  • 1999-2004 Volvo V70
Compatible with these L5 2.4L Engine
  • 1999-2005 Volvo C70
  • 1999-2007 Volvo V70
Compatible with these L5 2.5L Engine
  • 2003-2004 Volvo S60
  • 2004-2006 Volvo S80
  • 2003-2006 Volvo V70
  • 2003-2006 Volvo XC70
  • 2003-2006 Volvo XC90
PRICE $66.73
​​​​​​​BUY NOW LINK CLICK https://amzn.to/3i2tYoU
PRODUCT LINK =  https://amzn.to/3i2tYoU
AMAZON .
  • Manufacturer  = This one
  • Brand  = This one
  • Model  = ‎Ignition coil
  • Item Weight ‎= 2.75 pounds
  • Product Dimensions  = ‎9.5 x 3.5 x 6.5 inches
  • Item model number ‎= Uf-341 C1258 5c1320
  • Is Discontinued By Manufacturer ‎ = No
  • Manufacturer Part Number ‎ = ENAIC965205
  • OEM Part Number =  ‎C1258 5c1320 E371 52-1652 Ic471 Uf-341 30713416 9125601-6 9652
Going Above and Beyond for Our Customers
When and why should you replace ignition coils?
Ignition coils would fail due to age, overuse or simply manufacture defects. The material can crack or melt due to the heat from the electrical terminals. Replace your ignition coils as soon as your car starts showing signs of misfire, the engine check light appears or if your vehicle manual suggest that you replace them after a period of time.
The symptoms of defective coils depends on the car in question. It could be a misfire, backfiring, burnt gasoline smell, or starting issues when your “Check Engine Light” turns on. This will appear on the dashboard as a CEL. Prolonged engine misfire will destroy the catalytic converter and can lead to engine detonation.
When replacing ignition coils it is best to have them replaced all at once. Keep in mind that if one of the coils goes defective, then the others are probably going to be defective in the near future.
The number of ignition coils in the car depends on the car engine, model and year. Do not assume all vehicles are the same.
Why Choose Our Coils?
  • Eliminate misfire
  • Direct replacement into vehicle
  • Durable as they come
  • Easy Installation
  • Custom-made for the road
  • Fit OE equipment with ease
  • Tested in real life situations
  • Most coils come pre-greased
THANK YOU.....
