Volvo VNL VNM Fog Lights Assembly
For SaleLights
Volvo VNL VNM Fog Lights Assembly 2003-2017,Driver & Passenger side(A pair)
- Special Feature : High Beam
- Voltage :12 Volts (DC)
- Position : Right
- Lens Color : Clear
- Lens Material : Plastic
BUY & PRODUCT LINK--- https://amzn.to/3AiYUaL
Product Description
Fog Lights Assemblies for Volvo VNL VNM 2003-2017 (a Pair)Compatible With:
Fog light fit for 2003-2017 2011 Volvo VNL VNM Truck
High-quality fog light bright. Its perfect combination of flood and spot beams provides long distance irradiation and wide-spread illumination, light up the darkness.
Detailed Parameter:
- Material: ABS plastic
- Rated voltage: 12V DC
- Auxiliary high beam: 886 55W
- Fog lamp: 896 37.5W
- Shade material: PC
- Base material: PBT
High Quality
- After rigorous testing, this fog lamp has a very robust construction that can withstand harsh environmental and road conditions.
- Restore good night visibility and improve driving safety with our high quality fog lamps.
- Can be used on the left and right sides of the vehicle, is necessary for safety compliance replacement items, maintain the appearance of the vehicle.
Our Guarantee:
1 year warranty. If there are any questions ahout the product,we will reply your questions within 24 hours.If you are not satisfied with the product,we can provide you with full refund or replacement.
Please Confirm Oem Matches Your Current Part Exactly Before Purchasing, Otherwise, The Item Might Not Fit.
