Rear differential 1998 V70XC Bad Noise?
Hello
I have been having some unfortunate noises coming from the rear of my ‘98 V70XC...(250K miles)...mainly when turning and then accelerating out of the turn. It typically makes a loud Clunk, and happens more on left turns from the right rear, but does occur on the other side once and a while.
Today the roads were snow covered so I thought I’d see if the viscous coupler would engage and test if that was the issue...when the rear wheels engaged a ratcheting sound came from the right rear drive wheel.
Any ideas? I have another couplers I could install...I did check the parking brake shoes if they were hanging up...the noise is not coming from the angle gear and does not occur when turning slowly left or right. One thing that does seem common is when the car is coasting into a turn, then accelerating out of the turn... the loud noise will occur.
Thanks for replying
Dan
Thanks for replying
Dan
