98 v70 wagon question how to figure out if crank sensor or fuel pump is bad
Old 03-14-2018, 09:12 PM
Lumpy's Avatar
Default 98 v70 wagon question how to figure out if crank sensor or fuel pump is bad
All of a sudden engine quit.running and was wondering how to figure out if it's the crank sensor or fuel pump is bad. Any suggestions
Old 03-15-2018, 10:50 AM
firebirdparts's Avatar
If the crank sensor is working, you can read cranking RPM on the scanner. If the cam sensor is bad, after a couple engine rotations I think it'll set a pending code or a hard code for the cam sensor. You can also test cam sensors directly if you have a mind to. Fuel pressure is measured directly, and in fact a tire gauge will fit the test port on an 850. I am not sure if the 98 has a test port, but I think it does. I drive one, but I never really looked at that.
92_240_sedan
01-08-2013 11:23 PM
ZaphodBblbrux
07-02-2012 09:54 PM
Squeaky192
08-24-2010 08:15 AM
bigdaddyrdpjr
09-09-2007 10:30 PM
MattB850in
03-21-2007 12:52 PM
Quick Reply: 98 v70 wagon question how to figure out if crank sensor or fuel pump is bad
