v70 blowing ignition coils
Old 04-23-2018, 06:37 AM
lfovlov40's Avatar
Default v70 blowing ignition coils
Hi fellow Volvo lovers, I have a 2000 v70 t5 which I have just purchased. When I picked the car up, it was running perfectly, it had some oil in the engine bay and under car. It wasn't to bad but decided to degrease it and high pressure clean it. After I cleaned it, it started ok, but shortly afterwards, it began to misfire and run on 3 cylinders. I replaced the coils packs on the 2 misfiring, and it seemed ok, but shortly afterwards, it began to misfire again, and run on 3 cylinders, any suggestions?
Old 04-23-2018, 07:56 AM
firebirdparts's Avatar
Look at your plugs; You need to install something there that doesn't require super-high-voltage to fire. The car originally called for copper plugs (NGK, Denso, whatever) with a relatively tiny spark plug gap. Platinum and iridium plugs cause a lot of problems with coils just as a general rule, where the coil was never designed for that. I am not talking about the 2000 T5 specifically, but Volvos that I work on seem to me to have a curiously low-voltage ignition. A 2nd possibility is you may need to pay more money for a better coil. Just maybe. Finally, I would say make sure you blow all the water out of those plug wells. I'm sure you figured that out already.
P.S. I may be wrong about what was originally in there. If it was platinum originally, and you go that route, just make sure the gap is not at all bigger than specified.
Old 04-23-2018, 01:37 PM
tony1963's Avatar
My experience is that the coils cannot survive a douse in water. I have repeatedly pulled the coils off before washing the engine and then blow out the plug wells with compressed air.
For whatever reason, the design of the coils is such that there is open space where water can come in. The Volvo coils are not totally encapsulated in plastic like others.
Replace whatever coils you got wet.
Old 04-25-2018, 06:04 AM
lfovlov40's Avatar
Ok thanks guys for youré advice. I replaced the twol that weren't working with secondhand ones I bought, it ran on all 5 cylinders for a few minutes, took it for a run, and it began to splutter then ran 3 cylinders again. I left it overnight had a play with it, started it and it ran fine, with the secondhand ones. The engine mount near the cam belt needs replacing, just thought the engine mount may be causing the engine computer to shut down cylinders, to make run a bit smoother, does this sound like a possibility?
Old 04-25-2018, 09:27 AM
tony1963's Avatar
The mount will not effect the engine computer. My advice to you is to start with new coils. Also, as suggested by the other senior member, replace all of the spark plugs. We nearly always use the Denso brand plug which is inexpensive and works well.
Here are the plugs: https://www.rockauto.com/en/moreinfo...434016&jsn=374
Here are the ignition coils: https://www.ebay.com/itm/New-Ignitio...72.m2749.l2649
Before doing any more diagnostics, start with good ignition coils and plugs.
Old 04-26-2018, 06:08 AM
lfovlov40's Avatar
Ok thankyou for the sound advice Tony. I didn't think that the engine mounts would upset the ecu, but I had to rule it out by asking. I'm in Australia, parts are easy to come by here, its the postage that's a bit costly, prices for parts are more expensive here, but we have a much smaller population than in the us. so we pay more.
Old 04-26-2018, 06:11 AM
lfovlov40's Avatar
Thankyou to firebirdparts for your help as well, it is very helpful, and logical. Lfovlov40 (Tony from Australia)
Old 04-26-2018, 01:53 PM
Good luck! Sounds like you might have had some water down in there still.
Old 05-01-2018, 05:20 AM
lfovlov40's Avatar
Hi, just an update, I changed the spark plugs and coils, its running on 4 cylinders, under initial acceleration it hesitate a bit, seems to run on 2 or 3 cylinders, then runs on 4 cylinders. I'm thinking the oxygen sensor maybe faulty, can anyone help. Tony from Australia
Old 05-13-2018, 12:55 AM
Martin Haywood's Avatar
Check your wiring under the cover and you will find that you may need to run new wiring to the coils the heat after such a long time melts the plastic on the wiring and fuses them altogether. Therefore shorting out coils. I only found this out on mine, as a purple wire, which is the Cooling fan trigger wire, goes to the 5th coil. So it must tell the fans that the engine is running.
I'm new at Volvo but am a Euro Mechanic.
Old 05-19-2018, 05:32 AM
lfovlov40's Avatar
Hi, thanks Martin, I had my mechanic fix it, their was water in the ecu wiring. Replaced 2 of the coil packs with second hand ones. It also had a faulty oxygen sensor, and had the diagnostics cleared. It cost me $300 all up, but is actually going better than when I bought a month ago, and is using less fuel. You do have a point about the wiring getting hot and melting or making the flexible wiring shield brittle. I'll just have to keep an eye on it, but I'm very happy now
boiseone
04-02-2010 07:02 PM
roytoronto
04-26-2009 10:59 AM
roytoronto
04-05-2009 09:04 AM
Ham
01-16-2007 10:00 PM
AT Girl
08-12-2005 09:49 PM
Quick Reply: v70 blowing ignition coils
