Volvo v70 awd 1999 electrical problem
1 Attachment(s)
1999 Volvo V70 AWD Engine:2.5T ccm3 2435
YV1LW56C8X2624027 Problem after battery replacement . (new battery) All seemed normal before switching . ................................................. After battery replacement I can not connect with ECM from the diagnostic connector. Fuel gauge , no RPM displayed, no temperature , no numbers on the display instrument panel , almost no lights ( only light is ETS and engine fail) (I 've tried with another ETM no result ) The car starts but runs poorly All fuses are checked , ECM was sent to England to check and they said it was broken ( has been replaced parts and programmed again ) After ECM came from the workshop (autotec) are nothing got better .... all errors as before . I called Volvo but they had not heard of such problem . I need some advice and find fault. Can Dashboard (instrument ) error make that not have contact with ECM My main goal is to get connect with ECM and run diagnostics What may fail . ( can not contact Volvo VIDA Diagnostics garage but with Bluetooth OBD II Torque android , I have had get Connected 2 times (of 100 tries ) with errors P1630 and P1633 ) I have tried Norwegian Volvo forum but no one can help picture after car is started Attachment 16685 |
