“Transmission Performance Low”
Hi Folks - worrying warning came up on my 2012 V70 D5 today. Anyone had this before? Quite frustrating since I had Volvo Maidenhead change the transmission fluid last year to try to minimise future faults as she’s done 110k now. Many thanks https://cimg8.ibsrv.net/gimg/volvofo...0c59baa91.jpeg |
Hi,
Did you find the solution for "Low performance transmission"? Thanks, Florian Dumitru |
Originally Posted by florian_dum@yahoo.com
(Post 494031)
Hi,
Did you find the solution for "Low performance transmission"? Thanks, Florian Dumitru Hi The warning light went away next time I started the car and hasn’t been back since! She’s still going strong, 125k and never skips a beat... not that I’ve used her much this past 12mths 😩 Bizarre. cheers |
Stranger things have happened.
Were it my car I'd consider refreshing the transmission fluid with a drain & fill. It is 10 MY old and has 110K. Admittedly, I am not familiar with the "P3" design. I've owned a '99. '02 and currently an '07. All 3 benefitted from fluid refreshment. Obviously, do whatever you like. Cheers G&K |
Originally Posted by Georgeandkira
(Post 494069)
Originally Posted by t18tds@gmail.com
(Post 494037)
Hi
Ive been having this issue aswell as “URGENT TRANSMISSION SERVICE”
Im currently doing a ATF change because my car could not keep in a gear, nothing had leaked but when I’ve changed the fluid it was a dark brown, I’m in the process of topping it up half litre at a time and still finding this issue, next half litre will make it 3 litres.
anyone else had the problem of slipping gears? volvo v70 D5 2007 |
| All times are GMT -5. The time now is 07:56 AM. |
