2002 V70XC Dash failing
My dash guages, displays, and lights are intermittently failing. Sometimes all the lights and displays go dark, tach, speedo, fuel and temp gauges drop to zero or will be stuck at a reading, all display icons may be lit at times, when I shut the car off dash lights may stay on. While driving everything may work normally, then problems occur again. I am thinking a short/loose connection in the wiring. Just wonder if anyone knows the best connection(s) to start looking at before I have to tear off the dash and start checking everything.
Thanks. EChem Forum Member Forum Member Posts: 19 Joined: 26 Mar 2011, 00:17 Location: USA Model and Year: 2002 S80 T6 |
Its you DIM (Dashboard Instrument Cluster) some of the electronics fail over time. There are lots of threads about it and places to send them to be repaired.
